Cisco ACS 4.2: Question about the licence...
Answered Question
Dear,
When I began this project, we have start with the demo which is available to the Cisco download center.
We have purchase a license and we are waiting the CD/DVD with the license.
But… how can I transform the “demo” to a licensed version?
Should I reinstall the Cisco ACS?
How is stocked the license, is-it a registry key? A small file?...?
Thanks in advance,
Correct Answer by Premdeep Banga about 8 years 11 months ago
Take a backup of the current configuration you want to keep it.
System Configuration > ACS Backup > Backup Now.
Then when you get the full version, simply run the setup and it will automatically detect the trial version, and will prompt you, whether you want to keep the configuration or not, check to keep the configuration, and proceed. And you'll upgraded from trial to Full version.
There are no registry keys involved.
Prem
Please rate if it helps!
Overall Rating: 3.3 (3 ratings)
Premdeep Banga Tue, 08/26/2008 - 05:36
  • Gold, 750 points or more
Massimiliano,
This link is for CiscoSecure ACS "View" =P
I think we want it for CiscoSecure ACS for Windows.
Prem
Correct Answer
Premdeep Banga Tue, 08/26/2008 - 05:35
Prem
