Custom keymap tool
Aug 26th, 2008
Unity 5.x, one of our clients does not want the option 32 (review deleted messages) nor 422 (change fax delivery) -'while listening to main menu'. Can I use custom keymap tool to delete these, tried this but only seems to go to 3 option, not 32 option?...cheers, Jag
lindborg Fri, 08/29/2008 - 13:17
The CKM menus only go down to the main menu, message playback (header/body/footer), after message menu and setup menu. They do not go down into sub setup menu levels.
As such you can disable the option to review old messages (3) off the main menu but you can't go down to the saved message menu and disable _only_ access to deleted messages.
You can turn off 422 though - on the last tab (SEtup) you can uncheck the "2 Fax Delivery" option under Message Settings - this will do what you want there at any rate.
