SIP trunk from 2821 to Mitel 3300
Aug 26th, 2008
Hi All,
We need to setup a SIP trunk between ISR 2821 and Mitel 3300. Anybody has done this before? Any recommendation? Any sample config? Any underwater stone?
Overall Rating: 5 (2 ratings)
Alexander.Khlem... Tue, 08/26/2008 - 08:03
Thanks a lot for the answer. I have seen this link before - unfortunately it is not what I am looking for. It is about sip between Mitel and CUCM and I am looking for the info about sip between Mitel and 2821 router. But thanks anyway :)
rywalker Thu, 09/18/2008 - 18:35
Did you every find an answer to this? I have the same thing.
Alexander.Khlem... Fri, 09/19/2008 - 02:24
Hi, now, nobody came back to me so I had to it myself from scratch. Anyway, it was successful - it works :)
rywalker Fri, 09/19/2008 - 06:23
Would it be possible to share your sip config? or any gotcha's you ran into?
Alexander.Khlem... Fri, 09/19/2008 - 09:00
Hi, here below are the SIP config bits of the 2800 configuration. The only unexpected problem that we had was the fact that Mitel sends all numbers (including internal extension) as E.164 compliant (effectively puts + in front of everything). So you'll need to translate the numbers and take this + away.
voice service voip
allow-connections sip to sip
redirect ip2ip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
options-ping 90
no update-callerid
ip address ???.???.???.???
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
hold-queue 2048 in
hold-queue 2048 out
dial-peer voice 30 voip
description *** From Mitel ***
translation-profile incoming FROM_MITEL
voice-class codec 1
session protocol sipv2
session transport tcp
incoming called-number +32...
dtmf-relay rtp-nte sip-notify
dial-peer voice 10 voip
description *** To Mitel ***
destination-pattern 32...
voice-class codec 1
session target ipv4:???.???.???.???
sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPVOICE_IVS-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4)
Tommer Catlin Thu, 10/22/2009 - 08:17
Awesome config! Thanks for posting. (old, but still great) Did you use this for voicemail also or test it? I have a 3300 and a SX-2000 connected. I was thinking of doing the SIP connection to my 2851.
So Sx-2000 phones connect to the 3300, then 3300 to the 2851 to CUCM/Unity
Not sure it will, but maybe?
neelesh.gaekwad... Thu, 05/31/2012 - 12:11
can you tell me from which reference guide you have configure above stpes, because i have to terminate my E1 PRI line on voice gateway, so the call routing will be complex in my scenario:
i have to route the call from / to:
also , i have to configure SRST between two sites. I have tried to search for the configuration gude and can also able to dig out somthing but it is not upto my satisfaction.
