Media Master Problem
Aug 26th, 2008
Unity 5.X
VMO 5.01
User are getting the eamil but the Media Master tool bar is not showing up in the message frame. So there are no controlss to listen to the messages.
Ginger Dillon Wed, 08/27/2008 - 08:47
  • Blue, 1500 points or more
Hi -
You might take a look at this recent forum thread - http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&topicID=.ee835d2&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc1a402
The Media master bar is part of the custom Outlook form installed by ViewMail. Other things not mentioned in the above thread that can cause issues - From Outlook, go to Tools - select Options - select Other tab, then select Advanced Options. On this tab, select Add-in Manager and make sure ViewMail Extensions is checked. Occasionally Outlook will "disable" ViewMail - in Outlook 2003 click Help About Microsoft Outlook and select the Disabled Items button. If ViewMail is disabled here, re-enable it.
Hope this helps! Ginger
