CM Roles for IPCC 5.0(2) CRS users
Answered Question
Aug 26th, 2008
Does anyone know what CallManager roles need to be defined for each the CRS Users defined during the install.
AXL Service Providor User
Unified CM Telephony User
RmCM Subsystem User
Correct Answer by Chris Deren about 8 years 7 months ago
Both RmCm and CM Telephony (JTAPI) users need to be part of "Standard CTI Enabled" user group.
The AXL user needs to belong to a group with "Standard AXL API Access" role, you can use the ccmadministrator here as it belongs to this group by default.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Tue, 08/26/2008 - 11:58
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
paulcian_2 Tue, 08/26/2008 - 12:01
Thanks for the info.
It looks as if the CM Telephony (JTAPI) user is generate becuase I see that ID in my system with Userid_1 versus just the Userid. Do I need to have both?
Chris Deren Tue, 08/26/2008 - 12:45
  • Hall of Fame,
This is by design, you would need another one if you had HA CCX deployment, or 2 node IP-IVR.
Chris
