4 Domains , 2 x C350 Clustered - Help
Aug 26th, 2008
Anyone here had this kind of setup already?
2 x c350 - version 6.1.0-307
1.) I have 4 domains which are configured to be trusted
All domains have their own incoming and outgoing content filters...
I configured my LDAP to use port 3268 for all domains to query the
group on my AD per domain groups
Queries are working via test query on groups with respect to domains
where my user is a member.
My problems below;
1.) On my logs (mail logs) when i have it on production it seemed that
LDAP queries are not working.... I can ping all domains from my
Ironport C350
2.) Filters are not working too...html and txt footer... how can they
detect an outlook that uses html or footer.
hope anyone can suggest me or correct somethin..
thank you so much
whardiso Tue, 08/26/2008 - 14:33
Hi Kira,
What specifically in your logs shows that the queries are not working?
Are there no ldap queries listed whatsoever? or are there errors listed?
Have you enabled an LDAP debug log? If not, the following url describes how to do so: http://tinyurl.com/pnv57
The LDAP debug log could be helpful in determining the root cause.
