1200 Series Access points
Aug 26th, 2008
I have an problem with multiple access points losing the ability to telnet to them.They access points work fine but the only way I can get the ability to telnet back is to restart them. Has anyone else had this problem.
SJessulat_2 Fri, 08/29/2008 - 00:42
what kind of authentication do you use for the vty lines (local, radius, ...).
The easiest way would be to paste the config here, or at least a part of it.
Sebastian
Greg Johnson Wed, 09/17/2008 - 06:58
I am using Radius. This is what the config looks like.
Thanks for your help Greg
line con 0
password 7 110B15041317
login authentication local_auth
transport preferred all
transport output all
line vty 0 4
password 7 104C05180112
login authentication rad_auth
transport input all
line vty 5 15
transport input all
jeff.kish Thu, 09/18/2008 - 08:23
  • Silver, 250 points or more
Any chance you're maxing out your telnet sessions? It seems unlikely that you'd be hitting 16 unless you telnet around a lot each day and never log out. Still, might be worth checking out.
SJessulat_2 Thu, 09/18/2008 - 21:45
You could enable SSH and try to connect that way, maybe it makes a difference.
Additionally, if it is possible, connect via console when you're not able to telnet an AP and check the system output.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
