Can a default ring be changed?
Answered Question
Aug 26th, 2008
Hi experts,
Is it possible to bulk configure 7941 phones with a default ring, like Chirp2?
Correct Answer by Jaime Valencia about 8 years 5 months ago
unfortunately that needs to be selected on the phone itself, it cannot be done via bulk
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 08/26/2008 - 15:03
java
Rob Huffman Tue, 08/26/2008 - 15:48
Hi Isaac,
Just to add a note here to the great info from Jaime.
Here is a way of preventing specific users from changing the Ring Setting. So if you were using BAT to setup the phones you could set this so that all the phones that are being inserted would use the Default Ring (Chirp 1 I think)
Users are unable to change the Ring Volume/ and Ring Type if you disable the Settings Access parameter on the Phone configuration page. Complete these steps:
From the Cisco CallManager Administration page, choose Device > Phone, and click the phone for which you want to prevent a ring type change.
Choose Disabled for the Settings Access parameter under the Product Specific Configuration section.
When Settings Access is enabled, you can change the phone network configuration, ring type, and volume on the phone. When you disable Settings Access, the Settings button is completely disabled and no options appear when you press the button. Also, you cannot adjust the ringer type, ringer volume or save any volume settings. The option Restricted is available in Cisco CallManager version 4.1(3) and later. When you change Settings Access to Restricted, you can only access User Preferences and volume settings. By default, Settings Access is enabled.
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00800a6763.shtml
Hope this helps!
Rob
