CSS 11501 service redirect
sluciano
Hello
I am new to the CSS 11501 content switch. I have it working with 2 virtual webservers...however when the web admin does maintenance on one web server they shut down apache and leave the virtual ip up...the content switch still sends requests to the server with the apache service down....can i configure it to check a port and if it is down sned the request to the other server?
thanks
Steve
Glad it to hear works. The CSS is a pretty powerful platform and it can be configured in a lot of different ways. Be sure and check out the docs for other features you might be interested in.
Please rate if you found my comments helpful.
19 Replies 19
branfarm1
Level 4
Level 4
Steve,
Yes you can configure it to check a specific port. When you configure the service, add the commands: keepalive port xx, and keepalive type http. I'm not sure if you have to specify port 80 if you use an http keepalive type, but I'm sure it can't hurt.
Be sure and test this before you roll it to production -- stop apache on one of the webservers and do show service summary. The service should show as 'DOWN' after the keepalive timeout expires.
--Brandon
Brandon
thanks for the response. i will give that a try and let you know how i make out.
Steve
AJAZ NAWAZ
Level 5
Level 5
Steve,
I believe you may be looking for a CSS feature call 'sorry-server'. I have used it and icrc it will perform the redirect which based on your post is required:
<http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a0080093de8.shtml>
hth,
Ajaz
Ajaz/Steve,
The sorry-server feature is used when you only want to have one active server at a time. The sorry server is configured as a backup for when the primary server isn't available. When load-balancing between two or more servers, the CSS will automatically stop sending requests to the down server, as long as it knows the server is down. If you want to have only one server active at a time, the sorry-server is definitely the feature to use, as Ajaz indicated. However, if you want to load-balance between 2 servers at the same time, then you need to work with the keepalives and the keepalive port to ensure that the CSS see's the service as down.
--Brandon
Brandon/Ajaz
i definitely want to load balance between the two...i have it configured with the keepalives....i'm just waiting for the web admin to shut down the port.....i'll reply as soon as i can test it.
thanks
Steve
we shut the services down on WEBSERVER1 and the content switch continued to send requests to WEBSERVER1 on port 80. does the content switch send all requests to one server based on a session or individual requests.....here is part of the config..
!************************** SERVICE **************************
service WEBSERVER1
ip address 10.15.1.11
keepalive frequency 2
keepalive port 80
active
service WEBSERVER2
ip address 10.15.1.12
keepalive port 80
active
Steve,
Can you post a full config? Also, can you post the outputs of show service summary from when Webserver1 is shutdown, and the output of "show service WEBSERVER1?
here is the sh run....and the sh service summary
CSS11501# sh service summary
Service Name State Conn Weight Avg State
Load Transitions
WEBSERVER1 Alive 0 1 2 6
WEBSERVER2 Alive 0 1 2 22
WEBSERVERUK1 Alive 0 1 2 0
WEBSERVERUK2 Alive 0 1 2 0
Can you also post the output of "show service WEBSERVER1" and "show service WEBSERVER2"?
here you go...
CSS11501# sh service WEBSERVER1
Name: WEBSERVER1 Index: 1
Type: Local State: Alive
Rule ( 10.15.1.11 ANY ANY )
Session Redundancy: Disabled
Redirect Domain:
Redirect String:
Keepalive: (ICMP 2 3 5 )
Keepalive Encryption: Disabled
Last Clearing of Stats Counters: 08/27/2008 03:06:52
Mtu: 1500 State Transitions: 6
Total Local Connections: 50036 Total Backup Connections: 0
Current Local Connections: 0 Current Backup Connections: 0
Total Connections: 50036 Max Connections: 65534
Total Reused Conns: 0
Weight: 1 Load: 2
Weight Reporting: None
CSS11501# sh service WEBSERVER2
Name: WEBSERVER2 Index: 2
Rule ( 10.15.1.12 ANY ANY )
Redirect Domain:
Redirect String:
Last Clearing of Stats Counters: 08/27/2008 03:07:16
Mtu: 1500 State Transitions: 22
Total Local Connections: 38022 Total Backup Connections: 0
Total Connections: 38022 Max Connections: 65534
Weight: 1 Load: 2
CSS11501#
I can see in those outputs that the keepliave is still based on ICMP:
So the only way a service will go "DOWN" with this config is to shut down the box. You need to add a keepalive type to each service. Try adding 'keepalive type http' to each service and if that doesn't work, use 'keepalive type tcp'
--Brandon
we are still seeing the connections on WEBSERVER1.....type http didn't work so i tried type tcp
service WEBSERVER1
keepalive port 80
keepalive type tcp
active
service WEBSERVER2
keepalive port 80
keepalive type tcp
active
What does the 'show service WEBSERVER1' show?
Type: Local State: Down
Redirect Domain:
Redirect String:
Keepalive: (TCP-80 2 3 5 )
Mtu: 1500 State Transitions: 7
Total Local Connections: 50039 Total Backup Connections: 0
Total Connections: 50039 Max Connections: 65534
Weight: 1 Load: 255
CSS11501#
