Unity 5.0.1 Error when adding Subscribers; error 0x80070008 has occurred
Aug 26th, 2008
Hey,
i'm getting an error as well whenever i try to add or delete subscribers on Unity 5.0.1
My error says : 'An unrecognized error 0x80070008 has occurred: Not enough storage is available to process this command. \x0D\x0A
The new subscribber was not successfully added.'
has anyone seen this? or know how to resolve it??
thfergus Thu, 08/28/2008 - 08:10
  • Cisco Employee,
This error typically means the server ran low on nonpaged pool memory
for some reason. Non paged memory is virtual memory. It is space on the hard drive reserved for use when RAM memory in full. The CPU swaps data between the disk and RAM. When this nonaged memory is full it means the machine is out of memory. It can be caused by a memory leak or just too many programs running and taking up memory at the same time.
You can try restarting the the world wide web publishing service.
cuevas Thu, 08/28/2008 - 15:23
we rebooted the server, and it seems to have cleared it out. if it is a Memory Leak, what should be done to rectify it?
