remove line card 6500
Answered Question
sdaniels44 Tue, 08/26/2008 - 12:59
I was hoping that wasn't the case..
Thanks for the info.
Once the card is inserted, and the interfaces are loaded into the tables (ARP/IP/MAC, etc) and the IOS has loaded the microcode for the card, it can't back it out. You'll also see this with sub-interfaces (for instance PVC's under a serial port).
We once had a telco make a mistake and load 250 DLCIs to one of our routers. After all the DLCI's made it into the tables, they were there (under the sho fram pvc command) for quite a while.
