ACE - FT tracking
Aug 26th, 2008
Existng setup:
SW-Dist1 SW-Dist2
SW1 SW2
ACE 1 --- ACE2
Active
C1
C2
C3
where C1-3 are contexts, all contexts are active in ACE1.
These ACE are modules in 6504 switches.
SW1 and SW2 respectively.
SW1 and SW2 are trunked to Distribution Switches via port channels.
Requirement is to implement failover by tracking uplink port-channel availability.
How to achieve this? Any help is much appreciated.
Syed Iftekhar Ahmed Tue, 08/26/2008 - 13:59
  • Blue, 1500 points or more
With ACE you have 3 tracking options
you can track host (an ip), track an Interface and an HSRP group.
Tracking interface option is applicable for VLAN interfaces only. It cannot track port channel/ physical interface.
In your case the best option would be to track HSRP group configured on the uplink devices.
More details at
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/administration/guide/redundcy.html#wp1024578
Syed Iftekhar Ahmed
khaderbasha Wed, 08/27/2008 - 06:19
Thanks Iftekhar for the link, Is tracking HSRP group good for ACE if it is deployed in Bridge mode ?
Syed Iftekhar Ahmed Wed, 08/27/2008 - 09:45
Sure.
Infact HSRP tracking is the recommended option for bridge mode.
Syed Iftekhar Ahmed
khaderbasha Mon, 09/08/2008 - 06:15
Thanks Chris, can you kindly post your tracking configuration, appreciate it.
