Gateway Redundancy
Aug 26th, 2008
I have a client that has two sites that are in an active, passive configuration right now. They want to make it an active/active configuration and use the other one as a back-up. They have a single gateway at each location that does transcoding and local and LD.
I want to load balance between the two sites using device pools, however I want to make it so the gateways are fully redundant as well. If the one in site A fails then calls are routed out of the one in site B and the other way around.
Does anyone have any good articles or solutions here?
Chris Deren Tue, 08/26/2008 - 14:29
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Structure your Route Lists so that they reference the other site's Route Group as the secondary RG with the local RG as primary.
HTH,
Chris
