Remove enable tacacs authentication
Aug 26th, 2008
How to remove enable tacacs authentication on 6509 CatOS? I tried to enter new pw but it ask for old pw which I don't know. So the easiest way is to remove enable tacacs. Thanks in advance.
Sai
Premdeep Banga Tue, 08/26/2008 - 14:25
  • Gold, 750 points or more
Try,
set authentication enable disable all
set authentication enable local enable primary
Good luck!
Prem
Please rate if it helps!
J2NoomSai_2 Tue, 08/26/2008 - 14:32
Hi Prem
It work. Another question is how to reset enable pw without knowing the old one?
Sai
Premdeep Banga Tue, 08/26/2008 - 15:03
hmmm, I think that would require assistance from some CatOS expert. As the only way I am aware of is, using the "set enablepass", which requires you to be aware of old password.
May be some kind of password recovery. I might have to look for that option, but dont have it top of my head at this moment =P
Prem
Marvin Rhoads Tue, 07/18/2017 - 20:09
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
9 years after the original post - I think they may have found out the answer already. :)
