7961G-GE Install problems
Aug 26th, 2008
I was trying to connect a 7961g-ge to our network. If I understand correctly now after looking the 7961g-ge does not work with CM 4.0. To my question: I tried to use it with apower brick and it started and then shutdown. I think I figured out what I did and now I am wondering if there is a solution. I plugged it into the power brick and then I plugged a cable with POE into the phone. The phone won't power up now. Is this fixable or did I mess it up?
gogasca Tue, 08/26/2008 - 20:51
If no power up now, you can try to test the phone with a PoE switch or with a different power brick if u dont have a different power brick try different phone...
Not too much to do since will be phisycal other than replace either Phone or PW brick
Techie2008 Wed, 08/27/2008 - 06:16
Is there any kind of reset or fuse inside the phone that might have been tripped that I can fix? The Power Bricks are fine.
shabali52 Wed, 08/27/2008 - 07:50
Does it power on with the power brick now or doesn't power on at all?
Techie2008 Thu, 08/28/2008 - 06:43
It Does not power on with the power brick. Is there a reset or something inside the phone?
