CCNP-BCMSN and PVST
Aug 26th, 2008
Hello people...
I'm preparing to take the BCMSN (642-812) exam and the following question just arise...
Since PVST is a cisco proprietary protocol and you need to use ISL trunking encap between switches....
What happens when your access switches are 2950s or 2960s that DO NOT support ISL trunking ? would you need to implement PVST+ instead ?
makes sense ?
Glenn
Overall Rating: 5 (1 ratings)
yandy_ramirez Tue, 08/26/2008 - 15:07
when you turn on PVST, you automatically run PVST+, which runs over 802.1q trunks. The same with Rapid-PVST.
