CVOICE 642-436 Page 157
Aug 26th, 2008
I'm confused why are the dial-peers showing that the peer would be adding 911 (prefix on top of the already dialed digits. In effect output would be 911911 Also in step 4 how would that peer handle in and outbound calls when its a pots peer.
Michael Owuor Tue, 08/26/2008 - 18:37
  • Cisco Employee,
Hi David,
1. The default behavior of a POTS dial-peer is to strip the digits that were explicitly matched by the destination-pattern statement. One has to therefore make sure the digits are sent out by using the prefix statement. Alternatively, use the forward-digits command or change the default behavior using the no digit-strip command.
2. Pots dial-peer is the correct type of dial-peer to handle calls coming in through or going out of a voice port on the gateway. Voip dial-peers handle calls coming in from or being sent out to other network destinations.
Does this answer your questions?
Michael.
dschwenk7 Wed, 08/27/2008 - 06:41
Yes and thanks. Would you be able to point me to the location in the 3rd edition book where that POTS default dial-peer info can be found ?
I was in the middle of studying the CVOICE book second edition only to find out that the test was expiring. The 3rd edition seems a bit abstract meaning many of the building chapters in edition 2 have been removed with the 3rd edition jumping around more, less chapter building. I promise I wont ask more than the above!
