3750 Escape sequence
Answered Question
Aug 26th, 2008
  • Silver, 250 points or more
c3750E booting off wrong IOS image and need to know how to enter break sequence to get to rommon. Can someone send me the procedures. I am using hyperterminal on xp laptop. Tried ctrl c shift, ctrl fn break
nothing seems to work
Correct Answer by Mark Yeates about 8 years 8 months ago
Robert,
To enter rommon on the 3750E switch you will need to hold the mode button on the switch for a few seconds.
HTH,
Mark
Overall Rating: 5 (1 ratings)
Correct Answer
Mark Yeates Tue, 08/26/2008 - 18:12
  • Gold, 750 points or more
Robert,
HTH,
Mark
ropethic Tue, 08/26/2008 - 18:21
one more question,
how do I cd to the directory where I want to boot image from?
I typed boot flash:c3750e....
says file not found, how can I check directory for file name
ropethic Tue, 08/26/2008 - 18:25
figured it out,
boot flash:/dir/file
