Toll Bypass
Aug 26th, 2008
I have an issue regarding toll bypass.
I have 2 clusters: Cluster 1 and Cluster 2.
Sites that are on Cluster 1 are:A,B,C and
on Cluster 2 are X,Y,Z. Both the cluster are communication through intercluster trunk.
What I want to do is to make a PSTN call to site c on cluster 1 from site z on cluster 2, but that call should go through as a local call.
Traditionally if I place the call from site z to site c it'll be an international call, but I want to avoid that toll charge.
If anyone has configured it, please help me out. I have H.323 Gateways.
Marwan ALshawi Tue, 08/26/2008 - 22:05
on culster z creat a group contain Z PSTN gateway
put it in a partition access able through the ICT (interculster trunk CSS)
and make a route list called list Z include the route group u have just created
make a route pattren that match the digits will be dialed by C phones and make the route list as listz
on ur cluster 1
creat a route pattern same and the pattern similer to the one u created on cluster 2
but this one in the route list chose ur inter cluster trunk pointing o the culster two
and u have to have the right send digists and also the right dial-peers on the h323 gateway
this is the exact idea
make sure from the partitions and CSS for calls between two clusters and the gateway
good luck
please, if helpful Rate
