Connectivity between ONS 15454 MSTP
Aug 27th, 2008
Which Network card or module is required for fiber connectivity between two ONS 15454 MSTP.
Tom Randstrom Wed, 08/27/2008 - 06:10
I am not sure if this answers your question.
The OSC-CSM or amplifier cards (+ OSCM) interface to the fibers leaving the MSTP nodes. These cards allow access to the wavelengths used for the communications channel between the nodes. The remaining wavelengths are passed through to other cards in the node (amplifiers, mux/demux, transponders, muxponder and x-ponders), depending on the network characteristics.
viyuan700 Thu, 08/28/2008 - 15:14
It depends on how u want to use 15454 for if just as SONET box or SONET & DWDM box. In case of SONET box u need a crossconnect card (apart from common cards)and 2.5G/10G (what ur box have) to connect both 15454. There will be some other cards which u can connect to ur routers etc.
If u have list of cards ur box has then i think possible to tell which card u can use to connect.
