Outlook Web Access Interfering with PDM
Aug 27th, 2008
I have PIX 506E with OS 6.3(5). I have only one public IP address which I assigned to PIX Outside Interface. I also NATed this public IP address to the Mail server running Exchange Server 2003.
I discovered I could not access PDM anymore after NATing Mail server internal IP address to the PIX Outside IP address.
What can I do in a case like this where I have only one public IP address that should be used for PIX Outside Interface and Mail server?
See my config below.
name 192.168.16.1 Server
access-list outside_access_in permit tcp any host 217.x.x.237 eq https
access-list outside_access_in permit tcp any host 217.x.x.237 eq smtp
access-list outside_access_in permit tcp any host 217.x.x.237 eq www
ip address outside 217.x.x.237 255.255.255.248
ip address inside 192.168.16.254 255.255.255.0
static (inside,outside) tcp 217.x.x.237 www Server www netmask 255.255.255.255 0 0
static (inside,outside) tcp 217.x.x.237 https Server https netmask 255.255.255.255 0 0
static (inside,outside) tcp 217.x.x.237 smtp Server smtp netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
access-group inside_access_out in interface inside
When I disable PDM with "no http server enable" command OWA works. But when I re-enable PDM OWA stops working.
Any ideas on the reason for this?
Regards.
a.ajiboye Wed, 08/27/2008 - 04:59
Thank you for your prompt response.
How do I configure for PDM connections on the "inside" interface?
Regards.
http server enable
http x.x.x.x y.y.y.y inside
x.x.x.x = inside IP subnet
y.y.y.y = subnet mask.
So for example
http 192.168.0.0 255.255.0.0 inside
Now if you have remote VPN configured - you will PDM from your VPN connection as long as the ip pool for the remote VPN is in the 192.168.0.0 - for example.
Or you could just RDPsession to an internal server, then run the PDM from that server.
HTH.
