VSS implementation
We are having 12.2(33)-SXH2a on our cisco 6500 chassis and we are trying to implement VSS. We want to use layer-3 dual active detection using BFD but the command to exclude the BFD interface from shutting down during the dual active detection is not accepting and it is giving an error message saying " Cannot configure exclution on dual active interfaces ". So can anyone help me out with this ?
tstanik Tue, 09/02/2008 - 05:42
  • Bronze, 100 points or more
This command will not support for the layer-3 dual active detection.
ajagadee Fri, 11/14/2008 - 08:37
  • Cisco Employee,
FYI.. 12.2(33)SXI for the Catalyst 6500 has been posted on cisco.com. Below is the release notes which should answer most of your questions.
Cisco IOS Software Release 12.2(33)SXI, New Features and Hardware Support
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps6970/ps6017/ps9673/product_bulletin_c25-503086.html
Arul
*Pls rate if it helps*
