firewall setup
Aug 27th, 2008
Hi all, when first configuring the asa, what are most peoples first steps, log in via the gui or command line? and what would you configure first, and would you do this in gui or command line ?
lee.reade Wed, 08/27/2008 - 02:07
  • Silver, 250 points or more
Hi Carl,
You will want to connect via the console and use the CLI, as if you use the GUI when you change the spefics ie inside ip address etc, you will most likely lose your connection, assuming your internal lan uses a different number scheme than then asa default. (192.168.1.0/24)
Check out the below for info on configuring device;
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/conf_gd.html
You will be interested in the getting started section, initially.
LR
satish_zanjurne Wed, 08/27/2008 - 02:14
1.If you are familiar with Cisco CLI, it is easy to configure using CLI.
2.ASDM gui is also good for creation of IPsec tunnel & group policy application.
Important things to configure first
1.enable password
2.Hostname
3.Management IP
4.Clock Settings/NTP
to make ASA functional
1.nat / static command
2.global command
3.access-list
http://cisco.com/en/US/docs/security/asa/asa80/getting_started/asa5500/quick/guide/5500gsg.html
http://cisco.com/en/US/docs/security/asa/asa70/configuration/guide/basic.html
HTH...
