Directory numbers
Answered Question
Aug 27th, 2008
Pls do somebody know, how to inteligently edit (for example delete more of them) directory numbers on CCM 4.2, I found possibility how to reach it on CCM 5 and 6 on Cisco pages. But I got CCM 4.2 and I cannot find it there in menus. Thx
Correct Answer by Jaime Valencia about 8 years 10 months ago
as you may have noticed this is not in any 4.x release, you can try the route plan report but there is no interface similar to what's in 5.x and 6.x
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Marwan ALshawi Wed, 08/27/2008 - 03:42
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
go to device then chose phone
then make a search based on directoy number !!
if helpful Rate
Correct Answer
Jaime Valencia Wed, 08/27/2008 - 05:41
  • Cisco Employee,
  • Hall of Fame,
    2011
java
