Basic CME upgrade help needed
richb1971
Level 4
Level 4
Hi all,
I can't find any upgrade procedure for CME. We have a CME 3.3 which doesn't support 7961s fully. Can someone point me to the upgrade path when system is live please. We have a 2851 ISR and CUE 2.3
Cheers
Rich
Jaime Valencia
a simple search on cco for "cme upgrade" returns the procedure, very first link you get
Installing and Upgrading Cisco Unified CME Software
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html
Cisco Unified CME and Cisco IOS Software Version Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
make sure to check the requirements for the version you want to see if your ISR supports it.
java
if this helps, please rate
java
