MARS 5.3 - Locate who/what is applying password reset on users account
Aug 27th, 2008
A users account within the AD is repeatedly being set to change password at next logon. How can I search for the cause in MARS or is this type of event not logged?
Overall Rating: 5 (1 ratings)
mhellman Wed, 08/27/2008 - 05:13
  • Blue, 1500 points or more
I believe it will have event id 642 in Windows 2000 or 2003. Google that event id for more information.
andrew-mccabe Wed, 08/27/2008 - 06:06
Thank you.
Can you explain how I can search for this event in MARS?
mhellman Wed, 08/27/2008 - 07:09
For this example, username is BOB. open up notepad and type:
642Security
Where is the tab key. If you use a space, this won't work. Now ctrl-a to select all and ctrl-c to copy.
Now create a query.
query type = events ranked by time
time range = whenever you think this happened
keyword = AND BOB
submit.
