Interface in shutdown, Link-LED stays on.
Aug 27th, 2008
I shutted down the GigabitEthernet-I/F on a cisco3845-router. The Link-LED stay on. Shouldn`t the Link-LED went off when the Interface is Administratly down?
The other side off the Cable is connected to a Catalyst. Does anybody have a expaination for this behavior?
Postal4x4 Wed, 08/27/2008 - 05:18
Are you sure it was not the other interface of teh 3845 that was shut?
Postal4x4 Tue, 09/02/2008 - 04:55
Are you using the CLI to issue the command? The reason I ask is I have had instances where issuing the command via a GUI did not acutally apply the command.
This is rather peculiar...
Chad Peterson Fri, 08/29/2008 - 12:21
  • Cisco Employee,
Is the link light amber or green?
I would expect an up link to be green, down link no light, and admin down to be amber.
0tgemmecker Mon, 09/01/2008 - 00:03
The link lights are green - on both sides (on the cisco3845 and the calalyst ws-x5225-module)
