12.4(20)T object-group/ACL/crypto map on 3825
Aug 27th, 2008
hi all,
I just upgraded into 12.4(20)T my router because of new object-group fonction that I already use on all my PIX.
Bad thing is : sounds not work
I use object-group to define all my LAN networks for my VPNs
After that I apply ACL in using object-group => no problem
problem appears when I apply ACL on crypto-map. A simple "sh crypto-map" shows me that's false : it finds "permit ip any any" whereas that should be all mashed lan description.
Is it a problem on new IOS or I missed something
PS : in using ACL with network addresses, that works like a charm, so just when I put object-group in ACL, that doesn't work
Giuseppe Larosa Wed, 08/27/2008 - 09:25
Hello Nicolas,
looking at feature description
Known restrictions are:
Restrictions for Object Groups for ACLs
•You can use object groups only in extended and named (not numbered) ACLs.
•Object group-based ACLs support only IPv4 addresses.
•Object group-based ACLs support only Layer 3 interfaces (such as routed interfaces and VLAN interfaces). Object group-based ACLs do not support Layer 2 features such as VLAN ACLs (VACLs) or port ACLs (PACLs).
The feature is new and they declare support only on L3 interfaces.
You could try to open a TAC case to ask information for the feature road-map.
Hope to help
