Direct Crossover or Switchport ffor ASA5510 Failover
Aug 27th, 2008
I'm not having any luck finding specs on Cisco's web site stating why you should use a direct Ethernet crossover cable (connected between two ASA 5510s without a switch) than using a switch between/uplinking two ASA 5510s.
I see notes that can use a direct crossover Ethernet cable between two ASA 5510s, but also see notes (ciscopress “Cisco ASA, PIX, and FWSM Firewall Handbook; second edition) that should you not.
If you are able to find a Cisco URL/white page stating which type is better, I'll buy you a beer
Thanks, Kevin
Overall Rating: 3 (2 ratings)
Jon Marshall Wed, 08/27/2008 - 05:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Andrew
Apologies as this is the 2nd time today i have posted an answer just after you.
Not doing it on purpose :-)
Jon
Jon Marshall Wed, 08/27/2008 - 05:23
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Kevin
Don't know of a specific white paper/URL so no beer :-( but if you use a crossover cable then the only thing that needs to fail is the active ASA for it to switch to the other ASA.
Using a switch introduces a single point of failure. If you use 2 switches connected via a trunk then you have eliminated the single point of failure.
If the firewalls are close enough i would use a crossover but you may want your firewalls in different racks in different parts of the data centre in which case using switches is the way to go. Because of the above i usually use switches.
Jon
ksvy_ksvy Wed, 08/27/2008 - 05:55
HOU140ffipt1-pri# sh run | grep failover
failover
failover lan unit primary
failover lan interface faillink GigabitEthernet0/3.1
Ok, I should have stated the environment; due to 3 of the 4 Internetwork interfaces being used for other LANs (inside, outside, and DMZ), we configured the 4th interface for both STATEful and LAN-Base. The test 2950 switch was configured for trunking and tested good, but the site were the failover ASA pair is to be set up, uses a 4500 series CAT OS coded switch.
Discussion among some of our support is to use a direct crossover.
So depending on the remote site's support configuring their CAT OS switch, to support the trunked ports for the two ASA failover interfaces, we're concerned about which of the two options to go with
failover polltime unit 1 holdtime 3
failover polltime interface 3 holdtime 15
failover replication http
failover link statelink GigabitEthernet0/3.2
failover interface ip faillink 10.10.10.1 255.255.255.0 standby 10.10.10.2
failover interface ip statelink 10.10.11.1 255.255.255.0 standby 10.10.11.2
ksvy_ksvy Wed, 08/27/2008 - 05:57
asa# sh run | grep failover
failover
ksvy_ksvy Wed, 08/27/2008 - 06:04
left out the setup; active-standby
thanks, kevin
