Call Manager / Unity test plan
Aug 27th, 2008
Has anyone taken the time to document a good test plan for a typical CM / Unity cluster. It seems I always finish up with an install and then sit and around and wonder did I do everything. I am looking for a check list of sorts that I can run through at the end of an install to make sure I have done everything...MoH , Conf , MWI etc etc
thanks,
Matt
Ayodeji Okanlawon Wed, 08/27/2008 - 07:07
  • Cisco Designated VIP,
    2017 IP Telephony
attached are some steps I have used recently for a new install.
You may need to adjust the formating as this was in pdf, I just copied and pasted some details in word to get you going..
All the best
