MARS 5.3.6 recovery DVD
Aug 27th, 2008
Hello.
Has anyone else tried to re-image a MARS 110 or 110R with the downloaded .iso for 5.3.6? I just attempted with 2 burned DVDs and was unsuccessful. It would load the initial menu where you can select Local or Global, etc... but wouldn't continue when I selected Local. It reported that the SCSI driver could not be located and would exit out. I just used a 5.3.5 disc and it is loading fine. I will image with that and upgrade to 5.3.6. I just wanted to see if anyone else has attempted to use the DVD for 5.3.6
Thank you,
Jeff
Farrukh Haroon Wed, 08/27/2008 - 08:18
  • Red, 2250 points or more
Did you very the MD5 has of the image with the one given on the download page?
Farrukh
jeff_groesbeck Thu, 08/28/2008 - 07:38
Hello.
I haven't done that yet. I will do so. It is certainly possible that there is a problem. I was in a bit of a time crunch so I went with the 5.3.5 image instead.
Thank you,
Jeff
