MoH setup on CCM 6.01
Aug 27th, 2008
Hi All,
We have CCM 6.01 set up. I have uploaded MoH file under media Resources > MoH Audio File Management, after this I went to Media resources > MoH audio sources and set the streaming number for the MoH file.
I have since then reset MGRL and the Music on Hold server and still I get dead air on the phones when the hold button is pressed. Have I missed anything here.
Will rate helpful posts. thanks
Overall Rating: 4 (2 ratings)
Jaime Valencia Wed, 08/27/2008 - 08:51
which codec are the phones expecting?? by default only G711Ulaw is enabled, if you need more codecs enable them under IPVMS service parameters
java
if this helps, please rate
