Problem with VIP IP redundancy in CSS11503
Aug 27th, 2008
Hi I have 2 CSS 11503 (ver sg0810401 ) configured with VIP IP redundancy, but in this configuration the connection through the CSS sometimes get lost, and the services are unreacheable.
When this happen I make a Show flows and I see the correct NATs between interfaces but in the browser i never get the answer of the service
branfarm1 Wed, 08/27/2008 - 09:48
  • Bronze, 100 points or more
I believe you need to setup an app session between the two CSS's and also add unique redundant indexes to each service and content rule. If my understanding is correct, the CSS uses APP to share flow state and redundancy information between the two CSS's, and the redundant index's keep the redundant services and content rules aligned.
For each service and content rule add 'redundant-index X' and add the same line on the corresponding service/content rule on the secondary CSS.
frandeprado Mon, 09/01/2008 - 04:42
Hi Thanks a lot the problem was solved configuring a Group and adding as destination services all the services I needed it.
Thanks a lot
