Static bypassing ACL inside?
Answered Question
Aug 27th, 2008
Hello
Need to double-check packet traversal in a pix 6.3(5)
I have webserver on the inside with public IP's.
The acl-inside is limiting access from passing the firewall towards the internet.
Webserver has the static (inside,outside) 1.1.1.1 1.1.1.1 netmask 255.255.255.0
ACL-outside has a permit ip any host 1.1.1.1
Now, to my problem.
I thought you needed to add access for the webserver (1.1.1.1) to respond back?
So acl-inside need the acl rule "permit ip host 1.1.1.1 any"
NOTE, i have a "deny ip any any" at the bottom of my ACL-inside.
need som clarification thanks :)
Correct Answer by acomiskey about 8 years 7 months ago
You do not have to allow the return traffic from the webserver in the inside acl. This is the whole point of a stateful firewall. You do however need to allow any traffic that will be initiated from the webserver through the inside interface.
Overall Rating: 5 (1 ratings)
Correct Answer
acomiskey Wed, 08/27/2008 - 08:08
  • Green, 3000 points or more
azore2007 Wed, 08/27/2008 - 10:26
Thank you Adam
Must be going alzheimers already :)
