WLC - How to copy Self Signed Certs (SSC) across controllers
Aug 27th, 2008
I have 6 4404 controllers and a WCS (5.1.64.0). If I use the migration template in WCS to convert an 1121 AP to LWAPP the Self Signed Cert (SSC) is installed on my first controller. I can then audit it in WCS and import it to WCS. It then shows that WLC1 has the SSC but the other controllers do not. How do I then apply that SCC to my other controllers. I was thinking that it would show up under "Controller Templates" as being applied to 1 controller and then I could just apply it to the rest of them but that is not happening. Thanks.
Scott Fella Wed, 08/27/2008 - 16:47
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I would just create a new template, since the hash is shown on the wlc and copy that to the WCS AP Authorization Template.
dbuttry Wed, 08/27/2008 - 17:29
That is what I did however I have about 250 more to do. I was hoping that it would be a bit more streamlined. I could swear it has worked diferent in the past. Thanks.
Scott Fella Wed, 08/27/2008 - 17:34
  • Hall of Fame,
    2017 Wireless
usually there is a cvs fiel that is generated that you would import to the WCS and push that out to each wlc. Are you not able to find the template when you refresh the config from the WLC?
dbuttry Wed, 08/27/2008 - 19:23
I know if you use the stand alone migration tool it creates the file, however I am using the new feature in WCS (migration templates) to migrate autonomous AP from within WCS. I don't know of any file WCS creates. I will keep looking.
tkhan Tue, 09/02/2008 - 09:46
In WCS under "Configure/Controller Templates/Security/AP LBS Autorization", there should be a list of all SSCs. Just tag all of them an apply to one or more controllers. I backup 1400+ APs to a central WISM and this is how I did it.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
