Setting up Data Sources
Aug 27th, 2008
All,
Can anyone point me in the right direction? I am trying to set up a data source on my access layer switch but I am not receiving anything on my NAM module in the core swtich. Can anyone shed a little light on what I may be missing. Thanks.
Joe Clarke Wed, 08/27/2008 - 08:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
How have you configured the SPAN session? How have you configured the NAM? I assume you're using an RSPAN? It would be helpful to get a better understanding of the topology, as well as the version of code running on the NAM.
mrashby Wed, 09/17/2008 - 04:36
J,
I have configured the NAM and I have a netlow session coming from the access switches to the NAM. What type of session do I setup on the Distribution switches? I don't have any VLANs on those switches so I am thinking I can't do Netflow from the Distribution. How do I get the data from the Distribution switches to the NAM?
Joe Clarke Wed, 09/17/2008 - 07:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What type of switches are the distribution switches? What version of code are they running?
mrashby Wed, 09/17/2008 - 07:49
The switches are 6509s and they are running Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXH2a
Joe Clarke Wed, 09/17/2008 - 08:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can do Netflow and MLS on these switches if you want (see http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/netflow.html ).
You can also do an remote SPAN session to the core switch which contains the NAM. This will allow you to mirror traffic from the distribution through a special RSPAN VLAN to your core switch with the NAM. See http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/span.html for more details.
mrashby Wed, 09/17/2008 - 11:45
J,
I am configuring RSPAN and it is going okay but I am getting little confused though. The RSPAN config doc said that you configure a source session and destination session on different switches. This is what I have on the distribution switch, vlan 758 is on the core switch where the NAM module resides:
Session 75
Type : Remote Source Session
Source Ports :
Both : Te1/1-4,Te2/1-4,Te3/1-3,Te4/1-2
Dest RSPAN VLAN : 758
Egress SPAN Replication State:
Operational mode : Centralized
Configured mode : Centralized (default
Config On the Core Switch, vlan 757 is the RSPAN Vlan on the distribution switch:
Session 75
Type : Remote Destination Session
Source RSPAN VLAN : 757
I think I am missing something in my config can you see anything in my config?
Mario
mrashby Wed, 09/17/2008 - 12:35
Okay, so the RSPAN vlans should be the same on both the Distribution and Core switch, i.e. vlan 757 should exist on both switches.
Joe Clarke Wed, 09/17/2008 - 12:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, and it needs to be trunked between the two switches.
mrashby Fri, 09/19/2008 - 07:45
J,
Getting a trunk between my distribution and core switch turned into an issue my core switch has a 48-port ethernet blade in it but my distribution switch does not and I didn't want to use the ports on the supervisors either. So I just took an extra NAM I had and put in in the distribution switch so now I see all of the uplink interfaces in the switch. I plan to use RSPAN to get the information from the neighboring distribution switch. For the most part I am getting traffic to the NAM. Thanks for your help.
