IOS Upload on a 3845
Aug 27th, 2008
I got a brand new 3845, It has the IPBASE-mz-124-17a IOS, they sent me a disk of IOS's. Should I replace the flash with ADVIPSERVICESk9-mz-124-16b, or is that a jump too far? Also what would be the best way to do this?
Overall Rating: 4 (3 ratings)
scott.cummins Wed, 08/27/2008 - 10:40
Also, Do I WANT to over write the IPBASE, if I don't I don't have enough room.
So If I do a "copy tftp: flash: and replace my base software with the advipservices software, and reboot, will i expect it to boot up in the new IOS?
jtalbaugh Wed, 08/27/2008 - 11:06
This depends on what you want to do. For example if you plan to utilize BGP you will need Advanced IP Services. Personally I would utilize the Advanced IP Services because it contains all the features offered with the Base.
You can compare IOS images here but you may need CCO access.
http://tools.cisco.com/ITDIT/CFN/Dispatch
JORGE RODRIGUEZ Wed, 08/27/2008 - 11:22
  • Green, 3000 points or more
James is correct! no bgp support on ipbase
Additionally, when tftping the new code router will give you the option to erase code from flash, once you download the new code you need a reload .
3845#copy tftp flawsh
Address or name of remote host []? 192.168.25.100
Source filename []? newcode-advipservicesk9-mz.124-3i.bin
Destination filename [flawsh]? newcode-advipservicesk9-mz.124-3i.bin
Accessing tftp://192.168.25.100/newcode-advipservicesk9-mz.124-3i.bin...
Erase flash: before copying? [confirm]
scott.cummins Wed, 08/27/2008 - 11:52
I appreciate the info, I can tell you my boss bought this very expensive router for a single point-to-point DS3 circuit, i already have the t3/e3 card in and am just going to give it a basic confige to pass traffic between two points, Is it Okay if I just go ahead and overwrite the IPBASE IOS. It has been years since I have done any WAN routing
Joseph W. Doherty Wed, 08/27/2008 - 16:06
Before moving to advanced services feature set from base, I believe you need a feature license for it.
Personally, to save on licensing and maintenace costs, I use whatever feature set provides the features I actually require. So, if base is all you need, no real advantage using a higher feature set. (More advanced feature sets also often require more flash and/or RAM.)
As to the best was to upgrade, generally across an Ethernet port using TFTP or FTP works well. With the later ISRs, like the 3845, I believe you can also copy IOS to a USB stick. With a current ROM image, you might even be able to boot from it too.
PS:
"Also, Do I WANT to over write the IPBASE, if I don't I don't have enough room."
It's often nice to have a backup image, but assuming everything "takes" with the copy, shouldn't be an issue.
"So If I do a "copy tftp: flash: and replace my base software with the advipservices software, and reboot, will i expect it to boot up in the new IOS?"
Usually, but if the former IOS is still present, router will boot into the first valid IOS image it sees unless overridden with bootvar. If bootvar is used, you can (still?) have a problem if specified boot image isn't found and another valid IOS image isn't found on default boot device.
PPS:
BTW: Don't erase the newer flashes. If they are "formatted", you can delete individual files. To totally clear flash, format it. (Believe format command uses newer flash file structure [DOS like] vs. older erase command.)
scott.cummins Thu, 08/28/2008 - 12:48
Gentlemen,
Thanks so much for all the leads, I did go ahead and TFTP it even though it is as basiic a config as you can get. It went well, I just followed your directions. Why does it say "card type command needed for slot 2"
Richard Burts Thu, 08/28/2008 - 16:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Scott
You do not see the card because IOS is not sure at this point whether you want to use it as T3 or E3. Many of the older controllers were built for one or the other and the IOS knew exactly what it was. But some of these newer controllers can do either. (that is why it is a T3/E3 card - and that is why IOS is not sure yet what to do with it) Once you use the card type command to identify the function of the card in slot 2 then the IOS will show the card.
Rick
scott.cummins Fri, 08/29/2008 - 08:14
Hey Rick
Thanks for the info, I don't know too much about this. I am trying to configure it as a straight T3 connection point to point. SO If you have a link to the configuration commands for this particular module (NM-1T3/E3) I would be very grateful. I am looking myself, So I hope to find the command set soon
scott.cummins Fri, 08/29/2008 - 08:56
Hey Rick
JORGE RODRIGUEZ Fri, 08/29/2008 - 11:46
Scott,
to activate the card you need to tell IOS where card is installed e.i card type t3
say if card is installed in slot 4 of 3845 .
card type t3 4
controller t3 4/0
cablelength this is the coax cable distance bewteen router and T3 dmark, must not exeed 450 feet.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ft_te3nm.html#wp1066569
Rgds
Jorge
