etherchannel ports dropping need to disable negotion on HP
Aug 27th, 2008
I have set up a cisco switch (3650G) to perform etherchannel on two ports connected to a HP Prolient server. I followed the instructions, as per cisco, the ports keep dropping or flapping. I opened a TAC case and my engineer told me to hard code the nics or team not to negociate on the etherchannel. Someone have a doc on this? I've been trying to get a response from the vendor and it seems to be taking a while.
Giuseppe Larosa Wed, 08/27/2008 - 11:18
  • Hall of Fame,
    Founding Member
Hello Jason,
on etherchannel's member links use
channel-group x mode on
so that negotiation is disabled
EtherChannel On Mode
EtherChannel on mode can be used to manually configure an EtherChannel. The on mode forces a port to join an EtherChannel without negotiations. The on mode can be useful if the remote device does not support PAgP or LACP. In the on mode, a usable EtherChannel exists only when the switches at both ends of the link are configured in the on mode.
Ports that are configured in the on mode in the same channel group must have compatible port characteristics, such as speed and duplex. Ports that are not compatible are suspended, even though they are configured in the on mode.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swethchl.html#wp1275725
Hope to help
Giuseppe
