UCCX 5.02 OS 2003.1.2a OS Install issue
Aug 27th, 2008
I am building new UCCX 5.0(2) servers. I purchased new HP DL 380 G5's as per Cisco Server Spec sheet HP Part#417456-001 and I get fatal error upon install when it comes time for OS to install raid controller. I have confirmed that all parts are nailed down to the spec sheet. Anyone else have this problem? Here is the exact error:
The configuration of the array controller failed. This can be caused by unexpected hardware or a hardware failure within the system. Error code 2822
ebreniz Tue, 09/02/2008 - 11:38
  • Silver, 250 points or more
It is unsupported hardware. Have them make sure they have all required hardware for the support for OS 2000.4.4 install. If the system is hacked to support the larger drives it will not be supported. But You tried to install 6.11 on 5 different machines? The DL 380 G5 is supported for 4 / 5.X and 6. Is it possible to install an older version, and upgrade later?
