IOS name versus Feature Set
Aug 27th, 2008
Hi Everyone,
I would like to know if anyone knows how can we identify, using only the IOS name (i.e using only the letter of its name, for example, s, is-mz, js, k, etc) that those IOS is set to use an determined Feature Set?.
For example, the following IOS: "c2600-JS-MZ.122-32.bin" is set to "Enterprise Plus" feature set. From this, we know that the letters "JS-MZ" stands the Enterprise Plus feature set.
Another example, using the same platform, router 2600, the following IOS "c2600-IS-MZ.122-30.bin" is set to IP Plus. From this, we know that the letters "IS-MZ" stands "IP Plus" feature set.
Thanks everyone in advance!!!
Marcelo
jtalbaugh Wed, 08/27/2008 - 10:23
If I understand you it sounds like you've almost answered your own question.
I = IP
IS = IP Plus
JS = Enterprise Plus
SP = Service Provider
The MZ: M is for the memory location and the Z is the compression format.
Here is a doc that breaks down how to interpret an IOS name.
http://www.cisco.com/warp/public/620/1.html
This is also helpful:
http://tools.cisco.com/ITDIT/CFN/Dispatch?act=rlsSelect&task=search&searchby=software
m.yamaguchi Wed, 08/27/2008 - 11:26
Hi James,
OK. Thanks for your notes.
Best Regards,
Marcelo
Giuseppe Larosa Wed, 08/27/2008 - 10:42
  • Hall of Fame,
    Founding Member
Hello Marcelo,
there was a old link that could be accessed with a qualified access on CCO
I've found the following:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1818/products_tech_note09186a0080101cda.shtml
the codes change with the main release.
New IOS images have the name containing the feature set
http://www.cisco.com/en/US/partner/prod/collateral/iosswrel/ps8802/ps5460/prod_bulletin09186a00801af451.html
You can use the feature navigator and make a search by image name to decode
www.cisco.com/go/fn
some info about old name structure:
Image Naming Conventions
You can identify the platform, features, and image location by the name of the image. The naming convention is platform-featureset-type for images.
The platform variable indicates which platforms can use this image. Examples of platform variables include rsp (Cisco 7000 series with RSP7000 and Cisco 7500 series), c1600 (Cisco 1600 series), and c1005 (Cisco 1005).
The featureset variable identifies the feature package that the image contains. Cisco IOS software comes in feature sets tailored to suit certain operating environments, or customized for certain Cisco hardware platforms.
The type variable is a code indicating the characteristics of the image:
•f-The image runs from flash memory.
•m-The image runs from RAM.
•r-The image runs from ROM.
•l-The image is relocatable.
•z-The image is zip compressed.
•x-The image is mzip compressed.
in your case JS is enterprise plus MZ says how the image is executed.
the codes combines together to provide more info like k9 means 3DES o3 IOS firewall and so on.
Hope to help
Giuseppe
