Aug 27th, 2008
Is that AIR-AP1242AG-E-K9 can work simultaneously in AP and Bridge mode
thank for your help
Overall Rating: 5 (1 ratings)
bbxie Wed, 08/27/2008 - 22:32
yes, 1242 can work as root-bridge or non-root-bridge with wireless client
youssef_1985 Thu, 08/28/2008 - 00:11
but it capable to work simultaneously as AP and bridge because i want connected my 2 Outdoor 1242 with DS wireless.
thank for your help.
Scott Fella Fri, 08/29/2008 - 05:36
Can you specify the actual link to where you can setup one raido in bridge mode and the other radio as a root-ap?
bbxie Sun, 08/31/2008 - 17:43
Yes, Chapter 6 "configure radio setting" tells us 1240 can work as root/not-root bridge with wireless, there are two way to do it. One is to use one radio as both bridge and AP, however for better performance, in reality we prefer to use a feature called LRF for 1240, use 11a as backhaul, use 11b/g as wireless client connection. so what you can configure is like:
interface dot11radio 0
station-role root access-point
interface dot11radio 1
station-role non-root bridge
If you only have one radio available for example for 1310, then you have to use the 2.4GHz radio to work as both bridge and AP, but this definately will greatly decrease the performance:
station-role non-root wireless-clients
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
