distinctive ring for calls coming back from "Park".
Aug 27th, 2008
Is there any way to setup the distinctive ring for the call coming back from park after Hold Reversion Timer ?
Currently these calls are ringing the same way as other incoming calls.
Jaime Valencia Wed, 08/27/2008 - 13:39
  • Cisco Employee,
  • Hall of Fame,
    2011
unfortunately they're considered the same as any call so you cannot configure a particular ring for them
java
if this helps, please rate
