Remote Access VPN Fails after upgrade to 8.04
brad_olson
Hello:
Sorry if this has been posted, but I couldn't find it anywhere.
After upgrading my 2 of my 5510s to 8.04, my Remote Access VPN is not working. I can log in via Radius no problem. Once logged in, I cannot do anything on the network. When I try to telnet to any device, I get a blank screen with no response. Like it is finding the device but it isn't responding. Email, intranet, nothing works. Seems to be timing out. I tried updating to the latest Windows Client version, still no go.
Has anyone else experienced this at all? Any help appreciated.
TIA,
Brad
zhenningx
Level 4
Level 4
I have seen the same issue after upgrading to 8.0.4. And it is caused by the "IP Compression" option enabled under the group policy. After disable it, it works. Cisco just filled this bug recently:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu26649
Zhenning
10 Replies 10
Farrukh Haroon
Have you tried it for multiple clients?
How is the phase 2 / IPSEC on the ASA 'show crypto ipsec sa? encaps/decaps? Same for the VPN client?
Have you enabled NAT-T?
Farrukh
Farrukh:
Thanks for your posting also. I was going to look at those if the compression setting didn't sole it. Thanks for the recommendation!
Brad
zhenningx
Level 4
Level 4
Zhenning
Zhenning:
This seems to have done the trick. Thank you very much!
Brad
Great info there zhenning, good to know :)
Farrukh
Thanks for the tip! How the [censored] did this bug get into a release?
zhenningx
Level 4
Level 4
Just an update for this one. The bug ID is CSCsu26649 and it is supposed to be fixed in 8.0.4.6 which has a CCO ETA of September 22nd.
Zhenning
Zhenning:
Thanks for the information update! BTW, where do you get this data? Do you get emailed about it or do just follow it on your own? Thanks!
Brad
I got the info from my TAC case.
You can get updates from the bug toolkit:
Just simply put the bug ID in the Cisco Search page and it will take you there.
Symptom:
Cisco vpn clients are unable to view webpages when connected to ASA5510.
Page appears to be loading on browser but does not complete.
Conditions:
Cisco IPsec vpn client connecting to ASA5510 running 8.0.4.
"ip-comp enable" is configured under operative group-policy.
Workaround:
Disable compression "ip-comp disable" under the group policy.
Downgrade ASA to 8.0.3.
1st Found-In
8.0(4)
Fixed-In
8.0(4.5)
8.1(1.104
Farrukh
