FXO and Caller Id
Aug 27th, 2008
Hello Folks,
I have a gateway with 4 fxo ports, on the voice-port configuration I enabled the caller-id option. however randomly a few calls are disconnected. and i know it has to be with the caller-id, because when I disable the caller id option, no calls are disconnected.
do you know a workaround for this issue?
thank you
jbarcena Wed, 08/27/2008 - 14:12
  • Red, 2250 points or more
Let's take a debug vpm all while having the problem and also one when the call works (having the caller-id enabled) to compare them.
Also what is the IOS ver that you are using?
