sachinraja Wed, 08/27/2008 - 23:15
  • Red, 2250 points or more
am not sure if there is a doc like this.. We normally used to refer the datasheets of the switches, and find the technical and hardware differences between the switches.. am sure you can do the samething and try to develop competetive information..
HTH.. all the best..
Raj
andrew.burns Thu, 08/28/2008 - 05:26
  • Gold, 750 points or more
This information is only available to Cisco partners, from "Partner Central".
Andrew.
andrew.burns Thu, 08/28/2008 - 23:52
After you log in to the Partner Central go to Sales and in there you'll find a whole section called "Competitive Edge Portal". Everything you need is there.
Andrew.
