caller ID
Aug 27th, 2008
Hi All,
we are using CUCM 6.1. I am using hunt group with 5 members. when call comes in how can I distinguish the call comes from hunt group or someone dials member's DID directly? is there a way to configure calling name in hunt pilot number that user would know call comes from where?
gogasca Wed, 08/27/2008 - 20:59
  • Green, 3000 points or more
I have seen some customers configure a CTI RP
CFA to Hunt Pilot, then we have a CallManager service parameter to preserve this information (calling number/name) this should work.
LeeSnyder_2 Thu, 08/28/2008 - 03:08
I do the same to identify multiple numbers going to the same hunt pilot and just have a directory number for each with a call forward to the hunt pilot.
The inbound call then displays the directory number name to idenify the call as its a forwarded call, you even get the CLI of the caller at the bottom of the display so you dont even lose that.
alex goshtaei Thu, 08/28/2008 - 08:00
Thanks for reply,
That was very helpful. But it shows celled number not called name CLID. I configured CTI RP with extension 1500 with CLID "customer response". then forward all to 1599 which is pilot number of hunt group. when someone calls 1500 number, in the phone only show "1500" and doesn't show the name "customer response".
any suggestion would be very appreciated.
thanks
Alex
