multiple IPs on ASA 5505 - connection problem
Farrukh Haroon Wed, 08/27/2008 - 23:25
  • Red, 2250 points or more
Your route entry seems strange:
route inside 192.168.42.0 255.255.255.0 192.168.42.4 1
192.168.42.4 is supposed to be in the same subnet as your inside interface. Also is it possible to post any syslogs for this denied traffic?
You can also run a 'packet-tracer' simulating this traffic coming from the outside interface.
Farrukh
Farrukh Haroon Thu, 08/28/2008 - 05:26
"that both ASA & the 42 subnet connect to "
The ASA has three VLAN interfaces, none of which belong to 192.168.42.x
Farrukh
this is how my network is configured:
192.168.42.0/24 <-> Cisco3560 Vlan42 192.168.42.4
192.168.200.0/24 <-> Cisco3560 Vlan200 192.168.200.254 <-> ASA inside=192.168.200.4
192.168.201.0/24 <-> Cisco3560 Vlan201 192.168.201.254
using this all my LAN traffic go to Cisco 3560 that have a default route 0.0.0.0 0.0.0.0 192.168.200.4
this is the part that does not have problems.
in my post I asked about routing traffic coming from the internet into my LAN
the access-list\static combination for inbound smtp is working (using the interface public IP). any other public IP (as in different then the specified interface .126 IP) fail
Farrukh Haroon Thu, 08/28/2008 - 05:49
Change this:
To
192.168.200.254
You have a Class C from your ISP?
Farrukh
Farrukh Haroon Thu, 08/28/2008 - 06:25
Did u change the route?
Change it and run a packet tracer
packet-tracer input outside tcp 4.4.4.4 1045
63.x.y.110 443 detailed
Farrukh
Farrukh Haroon Thu, 08/28/2008 - 06:34
You don't need to worry about this command making any changes. Its just a 'diagnostic' command run from enable mode. You don't even have to do 'config t' to run it!
This will simulate the desired traffic flow and tell you WHERE its failing (NAT,RPF check, ACL, Spoofing etc.)
Farrukh
Farrukh Haroon Fri, 08/29/2008 - 13:03
Output seems perfect and the respective traffic should work.
A next step would be perhaps to capture traffic on the ASA outside interface for these public IPs to see if any traffic 'actually' reaches them from the internet or not.
Farrukh
