Faulty T1 ??
Answered Question
Aug 27th, 2008
Hi I have a point to point T1 I'm getting complaints from users that internet traffic and specific applications used over the circuit are slow I checked both the remote and local side and found what seems to be many errors but would like some additional advice.
I've attached a txt file that shows both interfaces and many errors. I have also contacted my circuit provider and he had did some non-intrusive testing and said he didnt see and issues at the time I asked him to take down the circuit after business hours and test. Unfortunatly the remote end is in a diffrent town so changing the WIC or cables would be a bit more difficult to do.
Any advice would be apperciated.
thanks,
Mike
Correct Answer by nramesh25 about 8 years 10 months ago
Hi Mike,
For this case, you have to check step by step, thisone might be a physical layer issue
1. Ask your service provider to give a loop (Local & Remote)and check whether errors are increasing on particular interface or not.
2. your-End physical connectivity
3. Then, Other-End physical connectivity
Ramesh
Overall Rating: 5 (1 ratings)
Correct Answer
nramesh25 Wed, 08/27/2008 - 23:22
Hi Mike,
Ramesh
carbonscoring Mon, 09/01/2008 - 21:12
Thanks for the help, contacted my provider told them about the high number of errors and AIS alarms I was getting. Had them do a intrusive testing after hours. They came back the next day saying that they thought they were having problems with the smart jack/NIU and will have a technician despatched in the morning.
thanks, for the help....Mike
don-sullivan Thu, 08/28/2008 - 13:15
Another option is depending on the hardware in use. There have been high error rates using a combination of the 2800 series router with certain revisions of the WIC-1DSU-T1 cards. The high error rates were observed on the standard and the V2 cards.
