Getting Started with Wireless: 1130ag access point as local authenticator
Aug 27th, 2008
I have set my 1130 ag as having a local radius server, including groups, users and ssids. I am having trouble getting the access point to use the local radius server. When I try to connect using eap-fast I get prompted for a user name and password but no attempts are registered on the radius server. Any help would be appreciated.
Current configuration : 2829 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret xxx
aaa new-model
aaa group server radius rad_eap
server 192.168.150.253 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid test13
vlan 1
authentication open eap eap_methods1
authentication network-eap eap_methods1
guest-mode
power inline negotiation prestandard source
username Cisco password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid test13
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.150.253 255.255.255.0
no ip route-cache
ip default-gateway 192.168.150.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
nas 192.168.150.253 key xxx
group luntan
vlan 1
ssid test13
user fangtanshi nthash xxx group luntan
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.150.253 auth-port 1645 acct-port 1646 key xxx
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
exec-timeout 0 0
end
Scott Fella Fri, 08/29/2008 - 05:22
I posted a config file for EAP-FAST... it works, because I tried it. If you have issues, then it has to be the way you are configuring the client side.
Trending Topics - Security & Network
