http keepalive on CSS
Aug 27th, 2008
users should able to access "http://virtual IP on the CSS/app/login.jsp", and on my CSS, I want to change to http keepalive from default ICMP, here is my config:
service Server2
ip address 10.122.49.18
keepalive type http
keepalive port 80
keepalive uri "/app/login.jsp"
active
after that, when I did "show keepalive", it show me "down" status:
Name: AUTO_Server2 Index: 2 State: Down
Description: Auto generated for service Server2
Address: 10.122.49.18 Port: 80
Type: HTTP:HEAD:/app/login.jsp
Keepalive Error: General failure
Encryption: Disabled
Frequency: 5
Max Failures: 3
Retry Frequency: 5
Dependent Services:
Server2
where is the problem, what else I need to do?
Overall Rating: 2.7 (3 ratings)
Syed Iftekhar Ahmed Wed, 08/27/2008 - 22:14
  • Blue, 1500 points or more
You can try to add "keepalive type http non-persistent" command and see if it works.
If it doesn't work then please post the output from the following commands....
CSS# llama
CSS(debug)# icp probe service server2 "/app/login.jsp"
CSS(debug)# icp probe host 10.122.49.18 "/app/login.jsp"
Syed Iftekhar Ahmed
shibindong Wed, 08/27/2008 - 22:55
thanks for your reply!
I actually configured 2 hosts:
!************************** SERVICE **************************
service Server1
ip address 10.122.49.17
keepalive type http
keepalive port 80
keepalive uri "/"
keepalive method get
active
service Server2
keepalive type http
keepalive port 80
keepalive uri "/"
active
!*************************** OWNER ***************************
owner L3_Owner
content L3_Rule
add service Server1
add service Server2
vip address 10.122.49.23
balance aca
advanced-balance cookies
active
!*************************** GROUP ***************************
group server1
add destination service Server1
add destination service Server2
active
but from the debug info, it looks different...
CSS11503(debug)# icp probe host 10.122.49.17
Probing 10.122.49.17:80(-) Probing SSL..
CSS11503(debug)# icp probe host 10.122.49.18
Probing 10.122.49.18:80(-) KeepAlive probe (5)
IP Address: 10.122.49.18
Port: 80
URL: /
HTTP Version: 1.1
Server Model: Microsoft-IIS/6.0
Server Date: Thu, 28 Aug 2008 06:51:32 GMT
HEAD Response: 401 Unauthorized
HEAD Support: Yes
Persistence: Yes
Keep-Alive: No
Request Depth: 14
TBR: Unknown
Connect Time: 1 ms
Rqst/Rsp Time: 1 ms
Pipeline: No
SSL: No
Syed Iftekhar Ahmed Wed, 08/27/2008 - 23:15
By default the HTTP keepalive will look for a response code of 200 and if anything different is received it will mark the server down.
The uri you are probing is returning 401 (HEAD Response: 401 Unauthorized ),thats the reason service is declared down by css.
Instead of probing the auth page you should ask your app people to give you some other uri to probe.
Another option would be add these two lines under service config
keepalive http-rspcode 401
Above commands will ensure that if CSS get 401 response then it should mark the service UP.
Syed Iftekhar Ahmed
shibindong Wed, 08/27/2008 - 23:24
here is the configure I added:
service Server1
keepalive port 80
keepalive uri "/"
active
service Server2
keepalive port 80
keepalive uri "/"
active
owner L3_Owner
content L3_Rule
add service Server1
add service Server2
balance aca
active
group server1
active
and my question is why I got different result for this 2 servers?
CSS11503# llama
CSS11503(debug)# icp probe host 10.122.48.18
Probing 10.122.48.18:80(-) KeepAlive probe (3)
IP Address: 10.122.48.18
Port: 80
URL: /
HTTP Version: 1.1
Server Model: Microsoft-IIS/7.0
Server Date: Thu, 28 Aug 2008 07:22:19 GMT
HEAD Response: 200 OK
HEAD Support: Yes
Persistence: Yes
Keep-Alive: No
Request Depth: 14
TBR: Unknown
Hash: dfbd1ee66a4e792349591b88660c0956
Connect Time: 1 ms
Rqst/Rsp Time: 1 ms
Pipeline: No
SSL: No
CSS11503(debug)# icp probe host 10.122.48.17
Probing 10.122.48.17:80(-) KeepAlive probe..
IP Address: 10.122.48.17
Port: 80
URL: /
HTTP Version: 1.1
Server Date: Thu, 28 Aug 2008 07:22:22 GMT
HEAD Support: Yes
Persistence: Yes
Keep-Alive: No
Request Depth: 14
TBR: Unknown
Connect Time: 1 ms
Rqst/Rsp Time: 1 ms
Pipeline: No
SSL: No
CSS11503(debug)# exit
CSS11503# sh keepalive
keepalive Show Keepalives
keepalive-summary Show summary info on all keepalives
CSS11503# sh keepalive-
Keepalives:
AUTO_nexthop00004 State: Alive 10.122.49.1
AUTO_Server1 State: Alive 10.122.49.17
AUTO_Server2 State: Down 10.122.49.18
CSS11503#
Syed Iftekhar Ahmed Wed, 08/27/2008 - 23:28
With CSS I dont recommend
"keepalive method get"
Unless you really need it
change it to
"keepalive method head"
with method GET CSS calculates a HASH value for the page and mark the server down if there is a slight change in the page.
Since you have changed th uri to "/" and as per ICP its returning 200. GEt rid of the following command
Syed Iftekhar Ahmed
shibindong Thu, 08/28/2008 - 00:46
I remove the 401 command, and created a webpage under root directory of web server, and confgured the "keepalive uri" point to that page. and it works.
thanks for help!
